this week the hose from my shallow well jet pumpto my bladder tank burst and as I was replacing it and the bladder tank was empty of water i took an air pressure reading and my car tester read 0 psi. i replaced the hose and everything is working like it was before but I don't think it's normal to have 0psi precharge. it even says on the tank, factory precharge at 28psi. what could happen if I leave it this way and what would be the benefits of adding some air? i took a reading when the tank water pressure was at 55psi and the air pressure read 50psi. my pressure switch is set for cut in at 48psi and cut out at 68psi
