vleespet
- Messages
- 49
- Reaction score
- 0
- Points
- 6
Opinions please
Anybody experience with these tanks??
WellMate Advantages
Corrosion-proof composite construction -
From the high density polyethylene inner liner to the fiberglass-wound and epoxy resin-sealed outer shell, WellMate ( Well Mate ) WM-Series tanks contain no steel. So they can’t rust.
Little or no maintenance -
Because WellMate ( Well Mate ) tanks contain no steel, there is no paint to scratch or touch up.
Longer life, greater flexibility -
WellMate's ( Well Mate ) unique air cell offers longer life than the bladders or diaphragms in steel tanks. WM-Series tanks can be installed with a wider range of pressure settings, so you can select the system pressure you want. What’s more, the bottom inlet/outlet assembly is pre-installed and comes with system connections to save time and money.
Light weight -
WellMate ( Well Mate ) tanks are quicker, easier and less costly to install than steel tanks.
NSF and/or FDA listed materials
The complete assembly meets stringent US requirements for water components. WellMate ( Well Mate ) tanks are environmentally safe, 100% lead-free. They will not introduce undesirable chemicals or elements into your customers’ water.
Replaceable air cell -
Easy to service in the field
WellMate Advantages
Light weight -
