View Full Version : Shower & bathtub Forum
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17]
  1. move castiron tub 1/4"
  2. Overlay tub is cracked at drain. Anyway to fix???
  3. Low water pressure moen shower
  4. Re-routing a vent pipe.
  5. Acrylic Bathtub Crack
  6. Tub replacement
  7. Push Button Diverter
  8. sewer odor frowm new tub drain
  9. difference between an americast tub I'd buy at Lowes vs one from a dealer?
  10. handheld shower from spigot with wall mount bar
  11. old leak-how to repair
  12. Quote - renovating shower-stall
  13. Question about height of shower head.
  14. Drain Vent
  15. Removing a shower base
  16. Remove iron stains from refinished tub?
  17. Coolest New Shower Heads
  18. Need thermostatic mixer shower with adjustable pipe centres
  19. Level Sterling Vikrell Tub
  20. Is there a 3-way inline diverter that attaches to the shower arm?
  21. Help with Kohler Tub Install Challenge
  22. Tub Caulking Problem
  23. symmonds temprol will not pass water
  24. Old Claw Foottub
  25. Neptune or Maax
  26. Bathroom Exhaust Fans - keeping things out
  27. Leaking diverter spout
  28. Floor Tiles & Tub
  29. Grout Questions
  30. Heat vent on the shower Wall
  31. Recommended Shower Drain for Sterling Ensemble Shower?
  32. confused by shower fixture options
  33. only warm water in shower please help!!!
  34. leak after replacing a Pfister avante cartridge
  35. Can I use both the shower & tub ports on a thermostatic valve?
  36. tub replacement help
  37. Wall mounted shower heads (spa style).
  38. Installed new shower head, now no hot water
  39. Drain problem in jetted tub/shower.
  40. cartridge for water main shut off
  41. Whirlpool bathtub framing questions...
  42. Delta shower temp control handle leaking
  43. Bath remodel
  44. Installing showerhead and spout
  45. Best way to install bathtub (esp drain) over crawlspace in cold climate?
  46. Help determining replacement bath spout
  47. New shower valve, limited hot water
  48. undermount tub ideas?
  49. Low bathtub faucet/shower pressure
  50. Offset Shower Adapter Serrated Thread
  51. I.D. this valve?
  52. Cartridge ID help.
  53. Under Shower Vapor Barrier
  54. Plastic shower base with tile walls?
  55. Installing a tub
  56. posi-temp valve and new trim
  57. helping my dad this weekend...
  58. Thermostatic mixer/diverter/flow valve.
  59. ID: Thermostatic Faucet + Cartridge
  60. Issue with Lining Up Bathtub Drain
  61. 2 bathroom fans don't work
  62. what delta plumbing parts am I missing here?
  63. Is this disposal plumbed right?
  64. Mortar Glass Block Shower
  65. Name that tub fixture... help with brand ID?
  66. black specks in bathtub
  67. Grohe 34436 - replace stop valve or the whole thing?
  68. Bathtub leaking under house
  69. Hole in ABS pipe
  70. Aligning drain pipe to Vikrell shower base
  71. 1 Week Old Shower - Water Pressure Disappeared?
  72. NPT vs slip fit diverter handle spout
  73. Installing a wall union for hand shower.
  74. Using existing tub water/drain for sink
  75. Single handle or 3 knobs
  76. Bathub/Shower/Tile Leak?
  77. Moving shower drain a few inches.
  78. Help - Major Damage from Failed Shower Pan
  79. Puzzling case of sewer smell only while showering
  80. Help in identifying fixtures
  81. How would you level this shower pan?
  82. Shower Diverter Question
  83. Caulking for shower
  84. Tub / Shower Valve Question
  85. ID tub faucet?
  86. grout repair question
  87. Minimum vertical distance from tub bottom to p-Trap inlet?
  88. Gerber Single Handle Shower Faucet Broken
  89. Non Kohler trim for Kohler K-305 valve
  90. Plumber's replacing shower body!?
  91. Adding shower to bathtub
  92. PF retrofit woes...
  93. Old shower pluming to new delta valve
  94. Self-leveling cement below new tub
  95. Hansgrohe Shower High Temperature
  96. What is the best shower head for high flow?
  97. Need new shower/tub mixing valve
  98. Tub incorrectly set in mortar
  99. Cast Iron Tub Install
  100. Leak from 2nd floor bathtub through ceiling
  101. Shower Body Stem ID
  102. Water Hammer knock - DANCO?
  103. Screwed up joist line up for fixtures
  104. 3/4" vs. 1/2" supply to shower?
  105. Removing water saver / restrictor from Delta shower wand.....
  106. sherle wagner sink fixtures?
  107. Ceiling supplies and Kohler K-303 Why Not?
  108. Valve placement in shower- how important is it to minimize elbows?
  109. Issue with hand shower and finished wall depth
  110. Need help on retail side for Sterling shower unit
  111. What is the aspirator for?
  112. Install cast iron tub in mud?
  113. No Pressure from Shower
  114. Bath tub faucet
  115. Scale in Shower P-Trap, Concrete Slab Floor
  116. Tub spout doesnt stick to wall.
  117. 3/4 or 1/2 shower?
  118. Inline fan to a soffit vent
  119. no hot water pressure
  120. no hot water /pressure/ upstairs shower only
  121. Can't remove tub drain, tools too shallow
  122. Dornbracht Shower/Tub Diverter Sticky
  123. Pex replacing PB, how much slack?
  124. Shower Diverter Issue
  125. Leak from 2nd floor bathtub through ceiling
  126. Mystery Leak
  127. Sterling Accord 4 Piece install
  128. Delta Jetted Shower - install problems . . .
  129. Stability & quality of Bootz tubs?
  130. Which is the real tub bottom?
  131. Height of tub spout and valve
  132. Premiere Walk-In Tub Drain
  133. Converting tub/shower to just a shower
  134. tub frame/tile question
  135. Framing tub skirt
  136. Lever drains
  137. Kohler RiteTemp shower problem
  138. Installing 3-wall Alcove tub with apron
  139. Bath tub drain.
  140. Plumber's putty drying time, and other loose ends...
  141. Basement Bathroom Rough-In
  142. Shower Arm & Drop Ear Elbow
  143. Cement board help needed!
  144. Silicone bead around pre-fab shower
  145. "Precise" rough in of shower? Need advice...
  146. Sterling Vikrell Tubs & Showers
  147. Cast Iron Tubs
  148. Ceramic Disk Bath & Shower Faucet
  149. Shower Head Location / Placement
  150. Moen cartridge was stuck, replacement leaks
  151. Bathtub leak
  152. Replacing old tub
  153. Shower is freezing, how to I adjust the temp valve?
  154. Drain pipe size
  155. condensation/leaking around base of Vikrell shower pan in basement
  156. 1 and 1/2 inch trap adapter for 2 inch drain?
  157. Shower door rough-in
  158. New Peerless faucet, water comes out shower head and faucet
  159. Bath Heater Problem
  160. Shower Cartridge Brand ?
  161. Starting total bathroom remodel:
  162. remove cartridge from Grohe model 33619
