GE Water Softener Err1
JayL999
CA
Hi,
I've got a GE Water Softener model GXSH40V-01, and a problem started when we noticed it kept running as if in regeneration and the tank filled up with water. After googling around, I thought maybe it was the rotor switch. Got one on Amazon, installed it, plugged in, and the motor started, but that didn't seem to fix it. Looking at the gear under the motor, noticed it wasn't turning. Looked at the gears, and they look to be a bit eaten. The rotor doesn't turn. Opened up the assembly, and everything looks fine as far as I can tell. When the lid is loosed, the rotor turns, but tightening the lid, it again won't turn. Does it just need to be lubed or something?
Thanks for any help.
