Stuck Linkage
baldtrainer
Last night, I was greeted with a lovely sight...bath water standing in the bathtub. Since this is our only bathtub/shower, I need to fix this ASAP so the family can bathe. I snaked the pipes, used Drano and plunged. Finally, I decided to take off the stopper (I have the kind that goes up to plug the pipe and down to unplug the pipe). The stopper was connected to the linkage and I tried to pull it all out...unfortunately, the linkage is stuck (which would explain why the plug hasn't worked in the 2 years I've lived here). I'm currently, using WD-40 to try and loosen it (apparently, this tub has never had anything done to it in 30 years). Am I doing the right thing? Is there anything else I can do to get it out? Thanks.
good luck
you will probably never get that out...
it has seized up years ago, you might try to man handle
those wires comming out of the face plate but I doubt it will
work...
If you plug up that face plate hole with a rag or sponge
and fill the tub a little with hot water,
you should be able to get a good suction going and plunge
that drain and get it running again.
Back
