I'm about to purchase/install a Toto Drake or Dartmouth - and am considering using the Fluidmaster waxless gasket. Any thoughts/recommendations for or against?
Also, although I've installed several toilets before - I've never been comfortable with my technique for sealing/aligning to the floor drain and would appreciate any pointers. If I stay with a wax ring - is it better to place the ring on the pipe flange and set the toilet on it - or stick the wax ring to the toilet and then lower it onto the pipe flange. I'm always concerned that I don't have the toilet lined up exactly.
By the way I've always used the wax ring with the plastic flange and embedded foam ring - is this a good choice as far as wax rings go?
All suggestions appreciated!
Dave
Dave
