I guess thats why you failed the first time...Call Backs? LOL That is something I don't have much of. LOL I'm not going to sell Tntent salt so what cheap shot do you have now?
No, there were two factors a lack of sales because I was overpriced because I listened to some hotshot national sales manager while spending a large amount of money on advertising that didn't work; partially my doing but the hot shot was directing me, and I ran out of money.
Cheap shot... You ran me and my company down every chance you got for years here and everywhere you followed me around the internet under all your various names. IIRC, I have not said anytinhg about you as a person, or about where you live or the type of house etc. you live in or your company. I do say you are wrong in some of the things you do. Right now it is how you arrive at the gpg of hardness in a person's water by adding 1.3 times based on the TDS is it? If I'm wrong, I'm wrong but if you are wrong you deny it and call it a cheap shot. Here's a copy of what you told someone a few months ago in a PM here where you added 13 gpg to his hardness AFTER compensating for his iron;
"Resin manufactures recommend regenerating resin about every 7 days. But with iron in the water, you have to regen it more often to keep the resin clean of the iron. For every part of iron, you add 3 grains of hardness. In your case you would add 3.3 to your hardness of 39.65 for a total of 42.95. There is also a compensated hardness. Compensated hardness takes into account hardness ions that are not measured with a standard test kit. The compensated hardness for your water is 42.95*1.3=55.83. So the actual hardness you want to remove is now 56 GPG.".
Tell us what other hardness ions are in his water other than calcium and magnesium. Name them.
And then I've seen you tell people to use a reserve of 10-20% of the total K of capacity instead of using a day's worth of gallons when using a metered valve.
All that requires salt to be used and my experience says it is a total waste, and you do it so you don't get complaints and if the person is in your area you're selling some of those people salt. Plus I doubt you are testing for manganese and compensating for it if there is any.
