farrider387
The air pressure tank started acting erratically two days ago, causing surges that result in water leaks and toilet fill valves not shutting, causing the toilet to run constantly. This happened overnight, which emptied the well and when I turned on the faucet ,sediment from the bottom of the well poured out.The air tank is 20+yrs.old. Do I need a new one ? It is a WellXtrol by Amtrol.. How hard is it to replace?
