I have used NuBath or NewBath...
I have used Nubath, NewBath. They are the same, just a spelling change. When I researched traditional remodeling I found It's easy to spend 5 to even 15 thousand dollars. The problem I saw was the inconsistency with the outcome. I was affraid of spending thousands of dollars and not being sure how it would turn out. There are thousands of reports from people getting ripped off from remodelers.
I did ALOT of research about Newbath and found that they have never had a single complaint. The better business bureau said they were "Accredited." I didn't know much about their product, Acrylic. But again, after ALOT of research, I found it has a higher resale value than normal remodels. However I found nearly every other acrylic remodeler reported with "rip-off reports." Apparently there is a big difference in newbaths acrylic and others here in alabama. Either way, I am very pleased with the job I got done. Maybe I could have saved a few dollars, but I wouldn't risk it if I were you. I'm proof that newbath does a fantastic job.
