Peak demand/Sizing help
fixitguy
Hi, I plan to buy an erosion chlorinator, special mixing tank, backwashed centaur carbon filter, and softner very soon for my well system. I have run the numbers for proper sizing using the instructions/calculator on Gary's website. Below are the results, but I'm not completely sure if I need to go with a 1.0cuft unit or a a bit larger due to my peak demand SFR. Any advice/tips would be much appreciated.
Nitrate - 0
Chlorine - 0
Alkalinity - 80-120
PH - 8.5
Hardness - 7grains (120ppm)
Copper - 0
Iron - 0
Main problem is SRB (sulfur smell, black slimey film)
3 person household, 2 1/2 bath, 1 jacuzzi tub, all other water using appliances/fixtures standard
3 people * 60gals/day = 180 * 7 (hardness) = 1260 total grains/day
1260 * 8days = 10080 rounded up = 11,000 total grains needed
Using the bucket test at a bathtub, the SFR shows approx 9gpm. I realize that is not the peak demand flow rate, which is why I'm not exactly sure what size to go with. Thanks.
How often does the jacuzzi tub get used? But any any rate it won't hurt to go one size up.
Jacuzzi tub is used approx 2-3 times a week, usually at night when no other water is being used. Would you recommend a 1.25 or 1.5cuft size? Thanks
The erosion pellet chlorinator system has a 21 gpm, flow rate. A 1.0 cuft softener has a 9 gpm SFR, your tub is at 9-10 gpm alone although you don't run a tub with both hot and cold full open. The next size up would be a 1.5 cuft with a 12 gpm SFR. 2.0 has 13 gpm and probably is what your 2.5 bath house with a big tub and 3 people needs. You only get one chance to get this right, so buy the right size instead of trying to save a few bucks and getting it worng and having to live with it for 10-20 years.
Thanks Gary! I most definitely want to get this right the first time. 2.0cuft it is then. I've read that a 2.0 is pushing the limit of a Fleck 5600. Any truth to that statement? The 5600 was my first choice, otherwise I guess I'll be trying to decide between the 2510 and 7000.
