bigkhong
You read it right. I got a $20,000 water bill recently and it's all due to leaky toilets. I am a manager at a 160 room hotel. All toilets are about 40 years old (pictures attached).
I found out that it was a toilet problem after shutting down all toilets. After shutting down all toilets, the water meter stopped dead in its track...
I have managed to reduce last month's water bill to $13,000 by religiously fixing running toilets. But there are still toilets that leak silently due to the fact that they are so old.
But the bill at $13,000 was still way high, a 50% occupied hotel with 160 rooms should run about $2,000 to $4,000 in water bill every month.
The problem is that our hotel doesn't have enough money to replace all of these 160 low profile one-piece toilets. Also, the retrofit kits are quite expensive at almost $200 per kit since these kits are made of brass and almost no-one manufactures them. I have been buying these kits from a Fox distributor but they cost so much and they only help partially.
Any suggestions of where to get cheaper kits so we could replace all 160 toilets? Or any other suggestions would be appreciated.
Thank you for your time.
Pics are below:
Pics are below:
