Squints2See
Hello, just stumbled upon this site today and it seems like a great place to get help on plumbing.....
Im putting in a new bathroom in my basement. There is already a toilet flange installed in the concrete (that for some reason they ran the drain from my furnace to?). Also, there is a boxed in opening thru the concrete slab down to the dirt with a 2" dwv pipe capped off sticking out. This pipe goes back under the slab opening only about 1 1/2 ft. and connects to what I believe to be the main drain leaving the house.(also, this 2" offshoot was not glued to the main drain, just shoved into the T fitting). The way it is layed out, I assume its for a shower. Unfortunately the sink will have to be installed further away from the toilet and shower on an intersecting wall. I have a bathroom and a half upstairs that are back to back and everything appears to drain to a main stack that goes down through the concrete basement floor. It is the only drain pipe. When I looked on the roof there is only one vent stack, however it is not coming from the main drain that goes down thru the concrete floor. All the upstairs fixtures feed into this drain, there is no stack that goes continuously from the basement floor through the upstairs ceiling and out of the house. So, it appears that every fixture upstairs must have its own vent that goes up and ties into to one vent stack thru the roof. My washer and dryer are downstairs and the washer drain is not vented. This house is only 8 years old.
My questions are,
Can I put in a trap under the new tub and drain it to the 2" pipe coming out of the hole in my slab?
Is it safe to assume that since there is a toilet flange concreted into the basement floor that just hooking up the toilet without a vent connected to it is ok?
The sink is going to be about 11 ft. from the main drain, can i run the sink drain horizontally around the wall to the 2" drain pipe im gonna use for the tub, and drain the sink there as well with a Y? (i know the 1/4" a foot rule)
It would be impossible for me to run a new vent stack to the roof without tearing out my upstairs walls. Can I use those "auto vent" devices on each fixture instead?
Sorry for all the questions, but I really want to do this right and "how a real plumber would do it". Thanks for any help you can give..
Todd
P.S - I had some details wrong about the current plumbing so I edited this message.......
My questions are,
Todd
