The only way to make what you have described work, is to make the washer end of the drain higher than the existing drain. You didn't say how much elevation you need to get gain to get a 1/4" per foot slope or what size the joists are, but if the elevation you need to gain isn't too much and the joists are like 2x10s or 2x12s, you can notch the floor joists enough to fit the drain pipe then bolt sister 2xs on each side of the joist to strengthen them.
