the_redhawk
Hi, this is my first post. I hope this is relevent to this forum.
My problem is as follows:
The septic pvc drain going from my basement to the septic tank outside brings in rain water around the pipe whenever it rains. (in the space between the septic pipe and the premade hole. The premade pipe hole is also plastic that was a piece of some 6" green plastic pipe cut and placed in the concrete when the concrete was poured. The leak used to be a little, but now it pours in. The house is only 3 yrs old. I am currently landscaping and will fix any sloping/settling issues after I am sure the leak is is fixed.
I tried hydraulic cement on the inside after I removed the old cement between the pvc and opening by chiseling it out and replacing it, but the leak returned when it rained. It is also cracking on the inside where I tried to make the repair like it was before. There is also dead space where I can't fit the cement (too deep to push it). Should that space be filled with a foam filler? Since my contact points are both plastic (pvc pipe and outer hole form), would I even use hydraulic cement or would I use epoxy, caulk, etc.? The space around the pvc to the green plastic form is about an inch between the pipes.
I think I'll need to dig up the outside as well. Do I use hydraulic cement like before, or an epoxy, special caulk, etc. on the inside and outside? Should I put rock under the ground around the pipe where it enters the house it to let water drain below the pipe and not set at the point where the pipe enters the basement?
Please help.
Thanks in advance,
Joseph W. Shipley
Please help.
Thanks in advance,
Joseph W. Shipley
