Results 1 to 5 of 5
Thread: Questions About Replacing Home DWV
    Default Questions About Replacing Home DWV
    it's a bungalow, built in 1959, on a basement
    can i use ABS to replace the steel pipes i'm breaking out of the concrete.
    at the end of the line the pipes was not far below the cement with hardly any 0-3/4 fill. can i lay ABS the same way or do i have to put it deeper. can't go too deep because i need to meet up with the 5" that passes under the footing
    The simple answer is yes, you can use ABS in the same way. Keep in mind the minimum slope for a drain is 1/4" per linear foot. I see no problem with the thin layer of concrete at the end.
    Plumber Cass's Avatar
    I would use PVC B4 I used ABS.
    hey guys. thanks for answers
    still wondering what's the best way to go about the job? at what end do i start?
    i want to cut the main line to the street a few feet inside the footing and hook up with a rubber coupling for now. do the front yard later. i can borrow a chain cutter from the store but i'm not sure if they're safe to use on an old pipe. i don't want to damage the pipe that passes under the footing but just get a nice clean cut i can connect the new system
    another Q i have is the toilet. the toilet seems to be sitting right on top of the large vertical pipe but the plumbing book i have says to use a Y fitting. can i just do it the old way? i don't want to move the large vertical pipe becaues it's already right next to the basement stairs. i'm going to do the bathroom later and replace the old fixtures but not the layout
    The rubber coupling needs to be a (banded coupling) will have a solid smooth, not coragated, stainless band around it, don't use the ones that just have a clamp on each end. Are you living in this or is this a vacation home. If you are living in this I would suggest you do a section at a time until you know what your into. If you cut it all out at once you may find your self in a situation that requires a plumber in a emergency situation. Not a good place for you to be in unless your best friend is a plumber.
