Results 1 to 2 of 2
Thread: Hot/Cold Reversed; Kohler Shower Valve
    Default Hot/Cold Reversed; Kohler Shower Valve
    Moved into a house with Kohler mixing valve in shower. Plumbing is approximately 20 years old. This is a one handle mixing value. Pull out to turn on; clock wise for cold: counter clockwise for hot. Handle is pentagon shaped clear plastic with pentagon shaped screw cover in middle of knob. Problem: The water temp flow is opposite of the markings on the handle. Clock wise produces HOT and vice versa. I have taken the mixing valve apart three times. Everything appears to be keyed such that alternative assembly is not possible. Am I missing something in the assembly, or is this thing simply piped backwards?
    Thanks, GDM
    Default Hot/Cold: Error
    Sorry. Posted to wrong forum by mistake. My error.
    GDM
