Stumped on venting situation
whackit
Los ANgeles
Hello all, long time lurker with my first post. I have a situation I have never run into. I can't figure out how to vent.
Corner bath with 7' windows on either side. There are structural steel posts at the ends of each window that I can't penetrate.
How do I vent this situation? It's a second floor and the joists run perpendicular to the tub. Ideas?
A 1.5" trap arm can go 42" before the vent
A 2.0" trao arn can go 60" before the vent.
Do those windows go all the way to the floor?
An inspector like to see a horizontal vent 6" above the flood level of the tub.
When it meets other vents, it would need to be 6" above those vents. With a 36" countertop, that would be 42" from the floor.
whackit
Los ANgeles
the windows don't go to the floor but I can't penetrate the floor to ceiling posts at the end of the window so i can't go horizontal in that space. the shortest run to vertical (from beneath) because of the window size is 6'6".
When I have been in that situation, I have used an "island waste yoke vent" system. The "yoke" would be in the wall under the windows, and the "vertical vent" would be outside the steel posts.
whackit
Los ANgeles
That was my first idea. Inspector said he wouldn't allow it because windows go to same level as tub, putting loop below rim (after sill plate etc).
Well, the return bend would still be above the tub's overflow, and if the tub had to be full before it started draining, you would have a good indication that something was wrong. AND, when an island vent is used, there is seldom a way to have the return bend above the countertop, and a sink does not even have an overflow. So if he allows it for a sink your tub should be a slam dunk.
