I have a shallow (15ft) well and the pump is a Gould jet 2 pipe system with the venturi installed in the well. I'm pretty sure the jet is clogged so now I cannot get over 30lbs pressure. I had the lines freeze and stirred up all sorts of debris! My well is by a river and the recharge rate is high. It is going to be difficult to pump water out of the well fast enough to get to the jet to try to clear it. Which means lots of labor to pay. I can order a venturi that would install on the pump itself. Would it still work if I did this and shut off the existing 1" pipe, turning it into a one pipe system?
