Adding sink drain next to washer
aads
Florida
I am new to plumbing and I want to add a sink next to the washer. Would like to know what would be the right way to add a drain and vent for the sink. How about venting with AAV system? I am in Florida. The sink would be on the right side of the standpipe.
Cacher_Chick
Test, Don't Guess!
First we would have to be sure that your sink is high enough to tie in above the sanitary tee for the standpipe. Then I would check your plumbing code to see if the laundry can be wet vented past the sink. I know I can do it here, but can't speak for Florida.
aads
Florida
The sink will be installed in a cabinet because it will be a bar/prep sink, don't have enough space for a utility sink.
The drain will have to be in the small cutout between the 2 wall studs, there is only 6 inches of space. Will it be possible?
Cacher_Chick
Test, Don't Guess!
The drain is going to have to stay outside of the wall to be tied into the vertical drain on the left. You cannot tie into the washer standpipe.
JerryR
Active Member
Florida
Here is the way my Florida home is plumbed. You can see the washer drain trap that ties into the vent. There is a sink in the cabinet off to the left outside the picture view. You can see where it ties into the vent above where the washer drain ties in.
I has to open the wall due to a washer hose gasket leak which saturated the drywall,
JR
