Results 1 to 2 of 2
Thread: Questions about installing a Kinetico K-60
    DIY Junior Member aceswidlab1's Avatar
    Dec 2013
    Indiana
    Default Questions about installing a Kinetico K-60
    I purchased this used a few months ago and just now have had time to try and install the unit. When i place the two tanks next to each other the two pipes that connect the two tanks seems to short. One of the two orings on each pipe is showing on one side. Is this normal? I would think that they should slide in further. Also my water was tested and I have a hardness of 25 I could not find online what disk number I should be using. There currently is a disk 4 in the unit.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    All the orings should be inside the connection. If you can not push the tank close enough to get them inside the connection, you may have the wrong size tank connectors. The model 30 has a shorter tank connectors than the model 60. I have a manual for the Kinetico. Send me an e-mail and I'll send it to you.
  1. Who can service my Kinetico head (pistons)? Indy Kinetico dealer has exhausted me
    By wm_son in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-10-2013, 03:06 PM
  2. Kinetico Quad 51 questions
    By noxid8 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-24-2013, 04:44 AM
  3. Installing Used Kinetico
    By fishnlunds in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-28-2011, 03:47 PM
  4. Frozen Kinetico, options/questions on "proper" install
    By dyeager535 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-25-2011, 10:36 AM
  5. Help with installing Kinetico Model 60 in MY house.
    By dwayneneel in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-24-2009, 12:34 PM
