Results 1 to 4 of 4
Thread: Bathtub Drain question
    DIY Junior Member stardog's Avatar
    Nov 2013
    Houston, TX
    Default Bathtub Drain question
    I never really thought about this being an issue until someone mentioned it to me yesterday. In my second bath is a standup shower. I want to convert this space and install a full size bathtub instead. If I do so I was informed that the entire drain would have to be converted to accommodate a bathtub and that the current shower drain would not be sufficient. Can someone please advise about this, and will this be an expensive overhaul (re: the drain issue, not the overall project)? Never gave much thought to this being a concern.
    Thanks in advance.
    Gary
    Houston, TX USA
    Jan 2008
    The size of the shower drain is not an issue, but the piping will need to be re-routed to accommodate the tub drain. How hard that will be depends on how the existing drain and vent is installed.
    A shower drain is suffcient for tub use.
    The tub takes a waste and overflow drain, which drops into a p-trap. You will need to move the p-trap.
    Nov 2013
    Houston, TX
    Thanks to both of you, at least I know it's affordable with some minor retrofitting. Just one last thought before I go. The current drain for the shower is approx. 24 in from the left wall and after tearing out the right interior wall (right side shower wall) I will have a lot of leeway for positioning the tub from left to right. Basically, I should be able to line up the tub drain over the current shower drain. Thinking in common sense terms, will this in and of itself minimize a lot of the necessary retrofitting as far as installing the drain pipes for the tub? Or are there other major considerations I am overlooking? Just thinking out loud.
  1. I'm an idiot! - Bathtub drain pipe question
    By madforrit in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-17-2012, 10:44 PM
  2. Shower to bathtub conversion - drain question
    By Jon Lehman in forum Shower & bathtub Forum & Blog
    Last Post: 07-26-2012, 06:54 AM
  3. bathtub drain question
    By congaman59 in forum Shower & bathtub Forum & Blog
    Last Post: 01-08-2010, 06:22 AM
  4. Stupid Bathtub drain question.....
    By UPEngineer in forum Shower & bathtub Forum & Blog
    Last Post: 03-21-2007, 07:51 AM
  5. Running a drain for bathtub question
    By trinculo54 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-19-2005, 02:02 AM
