Results 1 to 7 of 7
Thread: PVC vs Poly pipe around big trees
    DIY Junior Member leak_chaser's Avatar
    Aug 2013
    South Carolina
    Default PVC vs Poly pipe around big trees
    Which will stand up better to big tree roots?
    Thanks.
    Actually, maybe neither, because the biggest problem is usually the roots growing around the pipe and "choking" it. ANY plastic pipe can be squeezed closed by roots.
    In the Trades Wrenched's Avatar
    Apr 2011
    Vancouver, BC
    Big trees and plumbing generally tend to not get along.
    PVC piping has less give than Poly so will tend to crack slightly sooner.
    Sprinkler Guy Wet_Boots's Avatar
    Mar 2007
    Metro NYC
    If you really want to run a house supply past shallow tree roots, you would start at sch 40 PVC and work up from there. Poly pipe is not to be considered.
    To be really really conservative about it, you could even go with galvanized steel serving as a pull sleeve to encase plastic tubing.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    We sleeve poly all the time up here through 4" sch 40 PVC when we have a real rocky trench and under driveways. The stuff is damn near indestructible. Lay your 4" in the trench, glue it together, tape a golf ball to the nose of the poly & shove it in.
    All done.
    quote; The stuff is damn near indestructible.
    Maybe, usually, but I had a friend who had a sewer of it and the trees squeezed the pipe closed.
    Apr 2012
    ct
    Really? A picture of that would make quite the conversation piece
  1. Sub pump 370' down on poly pipe?
    By coyote in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-09-2011, 09:51 AM
  2. working with poly pipe
    By ctrautma in forum Irrigation / Sprinkler Forum
    Last Post: 04-09-2008, 10:37 AM
  3. galvanized vs. poly well pipe?
    By billp in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-17-2007, 05:23 PM
  4. Poly pipe
    By Kdog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-10-2006, 06:25 AM
  5. black poly pipe
    By dennis p in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-07-2006, 08:26 AM
