Results 1 to 5 of 5
Thread: Dipping my waters into the *Kaboom* setup
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default Dipping my waters into the *Kaboom* setup
    Picked up a Kaboom for the new *throne*.
    For the hoses that go into the tube, and or the one that *feeds* the unit from the fill valve, should I cut the tubing as short as needed on both ends to maximize the water ?
    In looking at how I have it', let's say about 6-8" of the extra hose slack + the volume of water in the device.....not sure how much LESS water is being put into the bowl due to this + or whether or not ultimately it will have any effects on the overall flush volume/performance..
    DIY Senior Member Reach4's Avatar
    Sep 2013
    Flush with the Kaboom device in place. Let the tank fill. Note the height of the water in the bowl. Add water to the bowl from a pitcher etc. If the water level does not rise after the added water, the Kaboom is not blocking too much water.
    I doubt that it matters, but there might be a tiny bit more water if you do your trimming on the output side of the cartridge instead of the inlet side, but the difference is probably not measurable.
    Mar 2011
    Long Island, NY
    Quote Originally Posted by chefwong View Post
    I tried one of those Kaboom things in my Toto Promenade toilet early last year. The tubing size was too small for the toilet setup, but I rigged it anyway. It did NOT work properly, much too much restriction. I wound up using the Kaboom in my older Kohler Memoirs toilet from 2006, where it worked properly. I no longer see those Kaboom cleaners in the stores, by the way. Internet yes. Brick and Mortar stores, no. Church and Dwight still shows it on their website, but could not find any (local anyway) stores in their where to buy search.
    Sep 2013
    I use the Flush 'n' Sparkle from Fluidmaster on my old 3.5 gallon toilet. I added a pinch clamp to the hose to cut down on the excessive refill water to save the life of the cartridge. That overfill is probably more a characteristic of the toilet, and your shorter fill and more compete emptying during the flush might make the Flush 'n' Sparkle still underfill for you. I went for the blue cartridge, but I would have used the white bleach cartridge if I were on sewer.
    Jun 2006
    I did not even knew these things existed until I just so happen to google about Sani Gloss glazing and came across these -inline- cleaners.
    I did not cut the tubing. I just increased the water fill a smigen before the top of the overflow tube just to make up for it.
  1. DWV setup Q
    By mrchaos in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2011, 05:35 PM
  2. Kaboom Toilet bowl cleaner
    By maemom in forum Toilet Forum discussions
    Last Post: 10-30-2009, 09:29 AM
  3. Kaboom Scrub Free
    By Terry in forum Toilet Forum discussions
    Last Post: 10-19-2008, 01:03 PM
  4. Muddy Waters
    By CHF in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-25-2008, 05:57 AM
  5. two well setup
    By aceto in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-05-2007, 09:13 AM
