sulconst2 said:why not just run a supply line from your hvac into the batroom. if you have forced air run a 4 or 5" line from your trunk. if you have baseboard heat run a loop thru the bathroom. if you can't afford the electric floor mats get some slippers.
did you hear me that time?
jdkimes said:I put one of the exhaust fan/light/heaters in and it works great. I think it was a Nutone/Braun model. It does blow heat and exhaust at the same time. Think of having a wall heater and an exhaust fan running at the same time (which by the way is also an option) Thing I like best is that this is a basement bathroom and not used all the time, I have the heater on a timer, the exhaust fan separate switch and light separate. So only gets heat when needed and the heater works very fast, it can be hooked up to a thermostat though.
One wish I have is that I would have spent the extra about 50% more for the most quiet version of this product. Get the quiet one it's worth it.
