Hey guys,
I'm a bit of a novice trying to install a pedestal sink in our bathroom which has a floor drain instead of a wall drain. The drain is on the floor about an inch away from the wall, between the two water supply lines which also come up from the floor.
I've read that S-traps are against code but it seems like the only way to connect a pedestal sink to this floor drain that's located almost directly under the sink.
I think using a P-trap with the two diameter arm length would force the sink to be very far off the wall when its designed to go flush.
Any advice on what to do?
