Results 1 to 5 of 5
Thread: New Pressure Tank-Cloudy Water
    DIY Junior Member marylibrarian's Avatar
    Aug 2013
    Missouri
    Default New Pressure Tank-Cloudy Water
    We replaced our ancient pressure tank today and the water is now cloudy. Do I need to run the water to clear it up or just let it settle?
    Moderator valveman's Avatar
    Mar 2006
    If you replaced an old air over water type tank with a bladder style tank, you may have air in the water from the old air injection system that you no longer need.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    I'd try to run it out from an outside spigot. If you do it inside, remove the aerator to get more flow and so it doesn't clog up.
    Jan 2008
    Virginia Beach, VA
    Valveman described it best
    You may have to pull the pump up and plug the valve (or hole in the drop pipe) as it lets air to enter the system. You may also need to cap or plug the Schrader valve on the check valve near the tank.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Nov 2010
    Maine
    Should make sure it's entrained air by letting water stand in a clear glass overnight. Clear water, no sand in the bottom means entrained air most likely.
  1. cloudy water
    By chikfarmer in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-22-2013, 11:00 AM
  2. Cloudy water in well now
    By Fast Eddie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2012, 04:10 AM
  3. cloudy water
    By JimIL in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-24-2011, 01:26 PM
  4. Cloudy Water in Tank After Refill
    By glnow in forum Toilet Forum discussions
    Last Post: 04-24-2009, 06:35 PM
  5. cloudy water
    By canadian in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-01-2008, 07:55 AM
