Results 1 to 5 of 5
Thread: Brine tube vibrating wicked
    DIY Junior Member theboneman21's Avatar
    May 2013
    New Brunswick
    Default Brine tube vibrating wicked
    HI all
    Ok so I have a 2 cyilnder system. The middle cylinder has the white tube attached to the salt tank.
    This morning I heard a wicked racket during the regen. I opened the closet and looked and the white tube was vibrating to the point where it was flapping against the wall and the tank. We are talking visible as though someone was holding it and shaking it. It was at thr tail end of the regen cycle, with about 1 minutes to go.
    Culligan Mark 89
    Any thoughts ?
    On a side note, we are two adults and a 10 month old baby. It is set to regen every second day with 10 pounds. Is that too much salt/too often to regen ?
    Feb 2011
    NW Ontario, Canada
    In the bottom of the brine tank there is a float that is supposed to close when the brine gets all sucked out. If it doesn't close, it will suck in air which causes the line to shake as you describe.
    May 2013
    New Brunswick
    Ok
    how do I "check it' ?
    What I mean is, how can I tell if it is staying open or not, aside from the vibrating ? Should I be looking for an obstruction of some sort somewhere is the float tube ? Or might it just be time to replace the float ?
    I wonder too - the float assembly is locked onto the white tube with a 90 degree elbow compression fitting. On occasion it would come loose and disconnect which would result in the brine tank filling with water.
    I reattached it and used electrical tape to wrap around where the compression fittings attaches to the tube. Might that be a problem ? I cannot imagine how, but maybe ?
    Feb 2011
    NW Ontario, Canada
    I'm not a Culligan Man so don't have first hand experience with that particular model but suspect they use the same principal. Remove the pickup float assembly and clean it. You can test how well it works by immersing it in shallow water, then raising and lowering it while sucking on the end of the tube.
    May 2013
    New Brunswick
    How do I clean it? just warm soapy water or use some rubbing alcohol ?
  1. air in brine tank tube
    By wully31 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-17-2013, 03:52 PM
  2. 4" Plastic Tube in Brine Tank Cracked
    By TJanak in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-04-2011, 11:33 AM
  3. vibrating pipes
    By donk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-24-2009, 07:32 PM
  4. Vibrating Pipes
    By mljim in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2008, 11:07 AM
  5. Vibrating Pipe
    By christiansen in forum Toilet Forum discussions
    Last Post: 05-26-2007, 03:42 PM
