Results 1 to 5 of 5
Thread: water to home is shutting off randomly
    DIY Junior Member mrsymo's Avatar
    Jul 2013
    arizona
    Default water to home is shutting off randomly
    Help! Is this a failure of the pressure reducing valve? From the street to my house is the cities water meter, a ball valve, then a Watts M55b M1 pressure valve. Every couple of days, the water supply to my home shuts off. Usually, I can open a faucet, go to the meter, and cycle the ball valve and the water will begin to flow again. Occasionally that doesn't work, but if I open the union in the line enough that water sprays out, then cycle it again, it will work. I'm beginning to think that I'm the first person in the world that this has happened to!!!
    Mike
    It is somewhat irrational, because normally, if the PRV valve fails, it fails permanently, so we cannot be sure what is happening without being there to actually test it ourselves.
    How old is the house? What kind of pipe is run from the street into the house? There could be some debris in the pipe, and it occasionally gets caught just right to block most of the flow. Or, it could be galvanized iron pipes, and the internal diameter is highly restricted because it is rusting from inside out. Lots of things possible.
    Jul 2013
    arizona
    The house was built in 1988. Its 3/4 inch copper running from the valves to the house. I'm going to replace that valve and see if it fixes it. It's in a great location...the guy who built the house (did everything himself...lot's of not so cool surprises..) put the valve in line then built a concrete block fence directly on top of it, so not a whole lot of space to work in...and digging in AZ isn't the easiest labor in the world!
    quote; and digging in AZ isn't the easiest labor in the world!
    It isn't in the heat, but you should not have to dig down 42" like you would if you were "up North". We usually install the PRV at the house where it is above the ground, not at the meter.
  1. Shutting water off when I am not home
    By stevep111 in forum Water Heater Forum, Tanks
    Last Post: 04-13-2009, 06:33 PM
  2. hot water shutting off
    By handijoe in forum Shower & bathtub Forum & Blog
    Last Post: 03-15-2009, 11:10 AM
  3. Computer randomly shutting down
    By GabeS in forum Computers and Stuff
    Last Post: 02-16-2009, 07:04 AM
  4. Odd Noise Like Water Shutting Off
    By jmcre8 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2006, 01:38 PM
  5. No water - pumptec not shutting off
    By CindyM in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-29-2005, 06:20 AM
