Results 1 to 5 of 5
Thread: Pulsing water
    DIY Junior Member lssurvey's Avatar
    Jul 2013
    Oregon
    Default Pulsing water
    Here's the scenario, we drilled this well 6 yrs ago, it is 320 ft deep. At the time of drilling it was producing 30 gpm. Water travels 1400 ft to the house where we have a constant pressure tank. All was fine till last summer we noticed some pulsing from the water hose. We had a well guy come out and look it over, he told us the well was going dry and we needed to drill a new one. Ugh, it just hasn't set well with me. I do not understand how a well with that much water can go dry. Now this summer we are noticing the same thing, pulsing from the water hoses. Some of the hoses are hooked in before the water even gets to the constant pressure tank. My thoughts are that this has to be in the pump its self. Any thoughts would be appreciated.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Pulsing? Is it like water hammer or is it sputtering like it has air of some sort in the water. Is the pump a submersible pump or what? What type of water line was run from the well to the house? Could the water line have gotten pinched or mashed by tree roots etc. Is there a hose bibb at or near the well?
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Constant pressure tank or constant pressure pump?
    Jul 2013
    Oregon
    Constant pressure tank. Pulsing like, lotta water, little water, lotta water, little water. There is a hose bibb at the well and it pulses also. Submersible pump
    Moderator valveman's Avatar
    Mar 2006
    I think you may have a Subdrive or Monodrive controller. There is no such thing as a constant pressure tank. If so I have solved this problem many times. See the link for a story similar to yours.
    http://cyclestopvalves.com/csvtechinfo_17.html
  1. G-Max Valve Pulsing
    By madmaxmarchhare in forum Toilet Forum discussions
    Last Post: 12-30-2012, 09:59 PM
  2. Hansgrohe Thermostatic Valve Pulsing
    By GoDillos in forum Shower & bathtub Forum & Blog
    Last Post: 06-30-2012, 07:52 PM
  3. well pump pulsing ?
    By Rhoni T in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-02-2011, 12:30 PM
  4. Pulsing dribble from tub spout??????????
    By inn_jay in forum Shower & bathtub Forum & Blog
    Last Post: 09-24-2008, 06:37 PM
  5. Water pressure pulsing/surging
    By Debbie7786 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-25-2005, 01:45 PM
