Results 1 to 5 of 5
Thread: Dead frogs in salt tank!
    DIY Junior Member Carol Brasby Clarkson's Avatar
    Jul 2013
    Florida
    Unhappy Dead frogs in salt tank!
    One morning after backwashing my water was very smelly. I checked the tank and found 2 decaying frogs in the salt tank. I removed the frogs and poured about 1 1/2 cups bleach in tank and did a manual backwash. Then I repeated this again. Since then the hot water is fine, but the cold water is still smelly and foul tasting. The water coming directly from the well is ok. I don't get it. Please help.
    Nov 2010
    Maine
    Tats why they make covers for the brine tank. Empty and clean the brine tank. Use a little bleach and rinse it well. Refill the salt and run a couple manual regeneration s back to back.
    Jan 2012
    California
    Add a cup of bleach to the brine tank and regenerate the softener to sanitize the resin. Some people on this site have actually said cleaning the brine tank is not needed... sigh I don't have a good reason, but frogs seem to be common in water treatment equipment, including inside of softeners and GAC tanks. Nasty little things!
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    I agree. Adding bleach to the salt may not disinfect all the salt. I would dump out all the old salt, use bleach and scrub the inside of the brine tank, then use new salt.
    Jan 2012
    California
    Oops, I meant to do what you recommended. Replace the salt, clean the brine tank, but also add some bleach to the new salt to sanitize the new system. Do not just add bleach to the old salt.. nasty.
  1. Is my expansion tank dead?
    By pigrew in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-04-2012, 07:41 AM
  2. salt forming around outside of brine tank
    By chris fox in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-27-2010, 08:19 PM
  3. Bladder tank dead?
    By abikerboy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-26-2006, 12:28 AM
  4. frogs in toilet
    By perky2 in forum Toilet Forum discussions
    Last Post: 07-09-2006, 10:23 AM
  5. Emptying water softener salt storage tank
    By DFMeer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-01-2005, 07:05 PM
