Results 1 to 8 of 8
Thread: Concrete coming tomorrow 3" pipe and flange on the outside
    DIY Junior Member joallen001's Avatar
    Oct 2012
    TN
    Default Concrete coming tomorrow 3" pipe and flange on the outside
    I have concrete being poured tomorrow and have a 3" pipe that will need a flange. I know they make 3" flanges that go on the inside but I would rather put it on the outside of pipe. What is the best way to wrap the pipe so room is left for the flange to be glued on. I was thinking something like foam pipe insulation and melting it out with a torch after the pour. I am a little afraid the foam may push in to far with the concrete weight. Just trying to save myself from having to chisel it out later. Any suggestions on this? Also is a flange with stainless steel the best to use on a slab pour? I am staying away from the all plastic flanges!
    You're on the right track with the outside fitting flange, and SS is always preferred over all plastic. Go to a building supply house, even a big box store probably will be OK, and get the foam sleeve that is made for the purpose.
    Default sleeve
    They make foam sleeves and also wrapped corrugated cardboard ones. You just "pick" them out after the concrete is poured, you DO NOT "melt" them out. Don't do like a homeowner here did years ago. He formed his area and then called for the concrete to be delivered. He told his wife to have them pour it inside his form. A few hours later the concrete company got a call. He said, "You delivered my concrete 4 hours ago and it is still in a big pile. When does it level itself out?"
    Aug 2009
    South*East
    We use a 4"x 3" 90 with 4" pipe coming through the slab. Then you can get a flange the fits inside the 4" pipe.
    John
    Nov 2006
    He said, "You delivered my concrete 4 hours ago and it is still in a big pile..."
    At least they got the slump right, eh?!
    "Great minds discuss ideas, average minds discuss events and small minds discuss people." --Eleanor Roosevelt
    John
    I like doing that too. That way I can cut it flush with the finished floor and glue it inside the pipe.
    Also with a 4", if the plumbing gets bumped I have some leeway that I don't get with 3"
    Default flange
    quote; glue it inside the pipe. I ALWAYS use a flange that slides OVER the outside of the riser. That way I can cut it off AFTER the flange is against the floor.
    DIY Senior Member DavidTu's Avatar
    Dec 2009
    Seattle, WA
    Terry, I don't follow... how does 4" provide leeway? It would seem if the pipe is not positioned correctly the 3" inside flange is also not going to sit correctly??
  1. Removed Closet Flange pipe chipped below concrete floor (basement).
    By Ron Buster Jackson in forum Toilet Forum discussions
    Last Post: 07-30-2011, 05:28 PM
  2. Adding bath sink to 1 1/2" pipe coming from kitchen
    By meplumbr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-26-2011, 01:38 PM
  3. Having plumber coming tomorrow to replace 3" flue with 4"
    By vtxdude in forum Water Heater Forum, Tanks
    Last Post: 12-02-2009, 07:48 PM
  4. pipe coming out of concrete at an angle
    By xnaron in forum Toilet Forum discussions
    Last Post: 01-29-2008, 08:03 AM
  5. How to install offset flange for cast iron pipe set in concrete slab
    By contessa301 in forum Toilet Forum discussions
    Last Post: 01-19-2006, 05:57 AM
