Thread: ABS screw on cap found on sewer line
    DIY Junior Member nm's Avatar
    Jun 2013
    california
    Default ABS screw on cap found on sewer line
    I mean IN the sewer line.
    Plumbers found the cause of our sewer line issues. They found an ABS screw on cap in the sewer line, probably dropped during pool construction. Wanted to get some opinions out there on what to do besides digging.
    Default cap
    NONE, unless it is small enough to be pushed all the way to the city sewer, at which point it is no longer YOUR problem.
    Jun 2013
    california
    HJ
    Thanks for the response. After almost 4 hours the plumber was able to grind, push, grind push the cap all the way to the city line. Thanks again for the response.
  1. Tree Roots Found In Toilet / Sewer Line
    By soca in forum Toilet Forum discussions
    Last Post: 06-12-2011, 08:41 AM
  2. I Found This Strange; screw found in supply tube.
    By dlarrivee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-23-2011, 06:43 PM
  3. screw on no freeze sump discharge line
    By webomen in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-25-2010, 04:00 AM
  4. Tapping new PVC sewer line into old existing clay line
    By Don Richmond in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-20-2008, 08:11 PM
  5. Sewer line to city line (sewer lateral) question r/o
    By H20Melon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-11-2005, 05:12 AM
