gojoe3
- Messages
- 70
- Reaction score
- 0
- Points
- 6
I need some advice on PVC solvent.
Which Oatey solvent would cure the fastest and be suitable for pressurized PVC pipe?
I have to replace my well pressure tank in the next few days with my plumber and want to be prepared for his assistance.
I do all the basic plumbing in my house because I like to and I hire my plumber to do the complex and/or difficult stuff.
He is OK with this and knows I do good quality work.
I have a 1" PVC line coming in from my well, with a Clack air injector installed prior to the bladder type pressure tank.
Years ago, I had given the Clack injector and two pvc unions to my water treatment contractor and asked him to install it, so that I could remove and replace or maintain the injector. Unfortunately, he only installed one union after the injector.
Now, I'd like to remove the injector and add another union prior to it and have everything be cured enough to be able to turn my system back on, ie. pressurize it.
My plumber came to install my new P tank last week but the new tank was delivered damaged. While he was at my house he stated that he was concerned about the well line new PVC fittings that I wanted to add. He said he was concerned about the amount of time the PVC solvent needed to cure and that it would be best if I could leave the water off for at least 24 hours so that it could cure properly.
We left it at that and I figured I would get as much work done to prepare for the install of the new P tank, so that he could just make it up and install it quickly.
I went out to buy the fittings and cement and am confused as to the best Oatey product to use. There was a choice for heavy or medium or another that I don't recall. I read the cans and the medium said it cured in a couple of hours? I think the regular said 24 hours? Is there a difference in its strength?
I appreciate any advice.
