The original owner of the home turned a crawl space into a dug out basement. However the stairs have a very high rise and as I want to fix this I'm faced with one of two solutions. The easiest one would be to cut the floor joist but it is directly under a wall and the section to be removed would be about 3 feet wide. The joist is a 2x10 and I would only need to remove about 5-6 inches to get the clearance I need. I know that sistering would be the best wya to deal with this but this joist is on the end and there is a joist to the est but not one to the west. Is there a way to safely support this and still get the extra 5-6 inches of clearance that I need. The other option would require using a cement saw and removing a portion of the cement floor of the basement as a way to chagne up the lay out of the stairs. I have never used a cement saw and would like to do this project by myself. Which way would be better or should I just sticke with cutting out the cement.
