Results 1 to 2 of 2
Thread: Compression Tool Rental
    DIY Junior Member JoeR's Avatar
    Feb 2013
    Caledon, ON
    Default Compression Tool Rental
    Where can I rent a Ridgid or other manufacture's hydralic compression tool in the Greater Toronto Area for Pro Press copper fittings. Don't really want to spend $1500.- $2200. for a one day job.
    You will just have to call around. Some supply houses that sell the fittings, may rent one. Most companies only want to rent them to "contractors" because it is too easy to damage them with improper use.
  1. tool rental
    By mneese in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-23-2011, 06:15 AM
  2. Is there a 3/8 compression to 3/8 Compression water shut off valve?
    By mnalep in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-21-2010, 05:28 AM
  3. plumbing hand tool.. for manually striking tool with hammer and driving a cement nai
    By firemanpipes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-05-2010, 07:35 PM
  4. Bathtubs for New Rental Duplex
    By DL in forum Shower & bathtub Forum & Blog
    Last Post: 07-01-2008, 06:30 PM
  5. Toilets for Rental Duplex
    By DL in forum Toilet Forum discussions
    Last Post: 06-30-2008, 08:57 PM
