Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Power Out From Electric Space Heater
  1. #16
    DIY Senior Member Kiko's Avatar
    Jul 2009
    Royal Oak, Michigan
    Smile Problem Solved
    I shut off all the breakers except for the bad circuit. Then I followed that cable in the attic with my non-contact volt tester, until it disappeared down a wall far away from where the power was out. I was about to give up, when later that day the lights came on and the outlets began working again (for a few minutes), even though the circuit I thought was bad had the breaker turned off (and the other breakers were turned on).
    I was following the wrong cable! The outage was part of a larger circuit that contains 7 outlets and 3 light switches. The "red herring" circuit contains nothing. It is just power leading to behind a wall to no devices that I could find.
    Once I determined the correct circuit, it was still tricky finding the bad outlet, because it had power, and there were no loose wires or signs of burning. It just didn't deliver any power to the other devices in the chain. Some internal defect in the receptacle.
    The real villain in all of this is the painter, who painted over the breaker box and covered the labels. He also painted over all the outlets, which should have been replaced long before I moved in.
    [This is a rental unit, but I have been doing all the maintenance, because the repair men they send out are unqualified and unprofessional.]
    The bad outlet is the one used for the wall A/C, which is rated at 1050 watts. My guess is that the A/C over time had begun to burn something out in that receptacle, and the space heater finished the job.
  2. #17
    Mar 2011
    Houston, TX
    Nice that you could get it fixed.
    The best thing a person can do when they move into a place is to make a Map of their Electrical wiring.
    It is Great for safety and keeps you from working on the unknown.
    Flipping breakers and checking outlets and lighting fixtures is easier when everything is working. It is best to have a drawing for next time something don't seem right.
    It it harder to work on something that is broke, if you don't know how it should work in the first place.
    Working on the wrong circuit would not give me a warm fuzzy feeling, Or could it ?
    I would recommenced operating the heater on Low.
    I use the ones with a 750 Watt setting, they seem to be safest. None of them should be left unattended.
    Glad to hear you have it fixed and lived too tell about it.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
  1. Grounding Whirlpool Tub Motor and Heater - Bonding Panel to Electric Water Heater
    By chuck b in forum Electrical Forum discussion & Blog
    Last Post: 02-06-2012, 09:01 AM
  2. Space heater cord hot
    By BellPilot in forum Electrical Forum discussion & Blog
    Last Post: 04-07-2011, 10:46 AM
  3. Safer: Electric Space Heater Or Bathroom Heater/Exhaust Vent
    By Briandl in forum Shower & bathtub Forum & Blog
    Last Post: 02-15-2011, 12:40 PM
  4. Replace dinosaur electric with electric, power or direct vent?
    By mr_littlejeans in forum Plumbing Forum Discussion & Blog
    Last Post: 05-02-2008, 03:36 AM
  5. Toilets with space for an electric baseboard
    By Perfectionist in forum Toilet Forum discussions
    Last Post: 04-07-2007, 04:31 AM
