Reccomend electric Valves into 1-1/4" PVC pipe
Dolphin
NV
I want to install some 110V electric valves in my well house project. All the pipe is 1 1/4" PVC, inside well house, 10 deg to 130 deg range of temp in the well house.
standard pressures, <80 psi
I would like one normally open valve, one normally closed valve... so I can apply the same control power to reverse them.....
Any suggestions would be appreciated.
Dolphin
NV
I assumed that was the case.... any good source for all these goodies? thx
Dolphin
NV
Thanks for the links and suggestions, much appreciated....
I think I can make a 3 way valve work... agreed, it would simplify....
doesn't appear Irritrol makes a 3way.... any other makers for this application in 3way?
thx
Irritrol is a "lawn sprinkler" company and as such ONLY makes simple valves which are all that are needed for 99.999999+% of installations. Do an Internet search for electric 3 way valves then sort out which of the "hundreds" of replies you want to investigate.
Dolphin
NV
I had already done that... Asco 3way valve was the best I could find, at about $1k price range...
two of these make more economic sense...
Dolphin
NV
Thank you for the Jandy recommendation.... these seem ideal, even their check valves...
your NSF comment made me curious....
for a small well house, that serves only a max. of 4 residences, do control valves require NSF? I would think not?
thanks..
