Results 1 to 14 of 14
Thread: Can I drain my softener into a nearby bathtub?
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Default Can I drain my softener into a nearby bathtub?
    We dont really use our basement and theres a bathtub <15 feet away from the softener. I know it wont look good, but since we dont really go down there often it's not a big deal. Can I drain the softener into the tub? Alternatively I could drain into the sump pump, but I was told not to since it's metal. The drain that I believe was installed for the softener appears to not be viable. Sucker hasnt been used for 30 years.
    Nov 2010
    Maine
    The salt water will rot the tub strainer out in short order.
    Mar 2013
    Here
    Darn, that sucks. I guess the only other option I have would be to drain it into the little drain next to the furnace downstairs (I think it's the furnace).
    The final rinse water of a regeneration will flush all "salt" residue off of the drain parts of the tub.
    DIY Junior Member Jeremy Kern CWS I's Avatar
    Jul 2013
    New Mexico
    The little drain you are speaking of. Are you sure that's not the condensate drain off of your heating/air system? If so you can not drain into that. A bathtub could not be used not only due to the fact that even if salt residue was washed some what away the minerals that you are trying to get rid of with the softener are all expelled down the drain and would also over time deteriorate the bath tub. If you are not using it you could pull the bath tub and then utilize the drain for the bath tub. Just make sure to install it in a sanitary fashion with an air gap.
    Quote Originally Posted by Jeremy Kern CWS I View Post
    A porcelain or plastic tub can't be used!! You've got to be kidding! Remove the tub and use its drain line!! Please tell us the WQA didn't teach you to think like that.
    Nov 2010
    Maine
    Here, I'll cut to the chase. A bath tub is not an approved waste receptacle for a water softener or any other drain line for that matter.
    I've seen a whole lot of softener drain lines dumping onto concrete outside. The concrete gets eaten away and always has white salt residue so the final rinse doesn't wash it all away
    Removing a bath tub is probably more of a task than he wants to get involved with although that would certainly be an alternative.
    Nov 2005
    Central Florida
    Remove tub strainer. Stick a piece of 1" (or 3/4" or whatever will fit loosely) down into the drain. Run the softener line into the PVC. As an old master carpenter buddy once said, you're not building a piano.
    Nov 2010
    Maine
    A little savage don't you think?
    Jul 2013
    New Mexico
    Tom your right that it might be a little more than he wants to take on but it would be the proper way to do the job shy of hammering the floor out and running the appropriate drain nearer to the softener. Plus if he ever chose to sell his home something would have to be done prior to sell anyway. Plus you could utilize the extra spce not taken up by a tub for storage or whatever you choose.
    Nov 2005
    Central Florida
    Only a little .
    Or, he could tell the prospective purchaser of the house that he will remove the softener, sell it or donate it to somone needing one, and the new owner can buy his own softener and deal with where to run the drain line himself or hire it done.
    Mar 2013
    Here
    If anyone can take a look at this thread and let me know if I could in fact drain into that weird corrugated tube that'd be great.
    I read a reply by Tom Sawyer that said floor drains often just drain into the foundation drain and if that is indeed a foundation drain that seems like it'd work. I dunno though. Thanks guys!
    Edit: nevermind, this appears to be the weeping tile drain and it wont work.
    DIY Junior Member DaPlumma's Avatar
    Dec 2010
    Houston Texas
    I take it you have it in a basement. And being there is a tub it must have a lavatory sink?? If so is the plumbing pvc or cast iron. Pvc hopefully, if you have enough space to install a pvc wye off of the waste arm coming out of the wall install a trap and drain into it with a air gap. But if its a pedal stool sink...uuuhh scratch those plans out. Unless your not using that sink then completely remove it and plumb it in for your need w/ air gap of course.
  1. Relocated well nearby now water has egg smell
    By deltadawn in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-27-2013, 06:29 PM
  2. Massive water bill shortly after nearby mains break
    By poppabk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-17-2013, 05:49 PM
  3. Bathtub Drain/Overflow Connection to Cast Iron Drain Pipe
    By darylm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-04-2012, 03:38 PM
  4. Replies: 1
    Last Post: 01-06-2008, 06:04 AM
  5. Condensate Drain and no floor drain nearby
    By Lakee911 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-19-2005, 10:05 AM
