The settings are incorrect unless you are regenerating with massive amounts of salt. Do you know what the actual hardness is? Assuming the system is programmed for a standard salt setting of 8 pounds of salt per cu. ft., the system would be good for 48,000 grains of salt. It can be programmed for as little as 4 pounds of salt per cubic foot with fairly good results and higher efficiency.
At your current settings, the system may only be regenerating every couple of months depending on how many people are in your house. I can post the programming sheet tomorrow. You should remove the grey clip that keeps the brine line in place, pull out the brine line and take a look at the button inside. It will have some numbers on it. It should be either 125 (it looks more like 123) or 250. This is the flow rate of the brine refill. It is also printed on the back of the valve, but regardless of what the valve says, it is always good practice to check to make sue the button matches what is printed.
With this information, we can walk you through reprogramming your valve to the correct settings,
Other imprtant information would be how many people in your house, actual hardness, iron level, manganese,
Your system is probably just fine, it needs to be programmed correctly.
If you do not know what your water hardness is, then a Hach 5B would be a good place to start.
Just found this, I posted the programming recently, check this link.
https://terrylove.com/forums/showth...-distributor-pipe/page3&highlight=programming
