Results 1 to 5 of 5
Thread: Securing Copper Tub/Shower Rough-In
    DIY Member DavidSeon's Avatar
    Jul 2012
    MS Gulf Coast
    Default Securing Copper Tub/Shower Rough-In
    I notice that the copper tub/shower rough-in I'm replacing didn't use any pipe clamps or the fitting mounting ears. The assembly is essentially free-standing and a bit wobbly, but firmed up somewhat by the installed trim pieces.
    Would a good plumber secure the rough-in to the wood framing or is it just something not worth worrying about ?
    Dave
    Old Retired Computer Programmer
    Obsolete and loving it
    Secure it! Now, depending on the design, it may have some screw holes for that purpose, or you may need to use some clamps or strapping around the supply pipes close to the valve.
    From your description, it sounds like it is too late, but a good plumber would stabilize and secure the valve "somehow". The somehow depends on how the valve sits in the wall. IF the trim stabilizes the valve, it is usually because it is stressing it.
    Jul 2012
    MS Gulf Coast
    Guess they were just lazy. Not too late hj, haven't installed the new stuff yet. Screwing the valve and shower drop ear to some blocking should do it.
    Thanks guys!
    Dave
    That is a start, but securing the valve itself so that when you tighten the screws on the trim plate you don't pull the valve forward would also be good idea.
  1. Securing PB and bibb
    By luvrbcs in forum Plumbing Forum Discussion & Blog
    Last Post: 06-22-2008, 05:25 PM
  2. securing shower base
    By Gord in forum Shower & bathtub Forum & Blog
    Last Post: 03-12-2008, 06:38 AM
  3. Securing gas pipe
    By MarkS in forum Plumbing Forum Discussion & Blog
    Last Post: 01-12-2007, 01:16 PM
  4. Securing escutcheons
    By maddfrog in forum Plumbing Forum Discussion & Blog
    Last Post: 07-20-2006, 07:02 AM
  5. Securing a copper pipe riser
    By jamckelvey in forum Plumbing Forum Discussion & Blog
    Last Post: 05-20-2006, 03:36 PM
