Results 1 to 3 of 3
Thread: Grinder pump alarm- how to troubleshoot
    DIY Junior Member Mplsmatt's Avatar
    Oct 2012
    MN
    Default Grinder pump alarm- how to troubleshoot
    Hello- we are staying a friend's cabin and the alarm on top of the circuit box for their grinder pump went off. I don't want to call the owner to bother them and I am trying to troubleshoot the alarm.
    The circuit box outside is a hydromatic but not sure of the actual pump specs. The documentation inside the box didn't provide any clue. I did cycle the circuit to see if I could reset the alarm but when I powered back on the alarm was still going. Looking online, it appears the alarm may be a high water level issue or perhaps a bad alarm switch but I cannot find any troubleshooting documentation online.
    Anyone have suggestions for how I should proceed? Thanks much!
    Oct 2012
    MN
    Also is there any danger to the pump itself if I leave it powered while I figure out how to troubleshoot? The "pump on" indicator light inside the circuit box is lit but I cannot hear the pump running. Just worried I will fry the pump if I don't cut the power. Thanks
    Jan 2008
    The alarm goes off because the liquid level inside the basin is too high. This could be because the pump or switch has failed. The only way to find the answer is to open up the basin.
    Unless you relish the thought of working in a sewage basin, you should probably check with the owner before getting in over your head.
  1. Grinder pump question
    By newhomeconstruction in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-17-2012, 04:04 PM
  2. Grinder Pump Problems
    By DebinFL in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-07-2011, 05:12 AM
  3. grinder pump clogging up
    By rburt5 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-12-2011, 06:48 PM
  4. Grinder Pump Issues
    By gardengirl38 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-09-2008, 05:48 AM
  5. sump pump versus grinder pump or both?
    By rrah in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-05-2007, 08:42 PM
