Nearly all replacement fill valves are adjustable in height, either of the tower or the float to accommodate tanks of different height to get the water depth right. Depending on the model of fill valve you have, you may need to twist it (like a screw), or give it a slight turn to unlock it so it can be adjusted in height. If you have the instructions and didn't throw them out, it should describe how to do it, or if you can indicate what model valve you have, someone here may be able to tell you. The only ones that typically are not adjustable are some proprietary ones made for a specific toilet, and even many of those can be adjusted as well.
