Supply pipe is often spec'ed by the OD. For example, 1/2" copper is actually 5/8" OD and 1/2" ID. Now, if you were to get 1/2" pex, the OD would be the same allowing you to use the same compression fittings (as long as you used the required internal stiffening bushing), so it gets called 1/2" even though the wall thickness is much thicker and the internally fitted connectors make it even less. That's what's meant by nominal size in this case...the OD is the same.
