Results 1 to 4 of 4
Thread: KitchenAid gas stove model#KGRS807SSS
    DIY Junior Member Mohsin67's Avatar
    Aug 2012
    Milton, Ontario
    Default KitchenAid gas stove model#KGRS807SSS
    Hi my gas stove is having problems, the front 2 burners won't lite also the oven and broiler won't lite, I can lite the burners with a match so the gas I don't think is the problem. When I lite the oven I hear it click and the gas come on for a few seconds then off again, usually you would hear the oven lite up in these few seconds, what part do you think I need?? And where should I look for it??
    Jun 2007
    North Carolina
    What you need is an appliance repair person.
    Sounds like the ignitor/flame sensor is defunct in the oven...the ignitor(s) on the stovetop may be bad. Could be wiring, could be the devices, could be the switch/valve.
    Once the system sends a spark, it senses if the burner is actually lit. If it isn't, it (sometimes) tries again. Why it didn't light could be the gas actually didn't turn on, or the spark was weak or non-existent.
    WOrking with gas can be dangerous, so to keep from blowing up the house, it's best to have someone that works on them fix it.
    Yakima WA
    Screw up with plumbing and you may have a leak or a drain that doesn't work well. Screw up with gas and you, you family, and you home are history. Get a licensed gas appliance repairman. Not everything is a DIY job, and this is one of them.
  1. Is there a place on Toto toilets where it says the model or gives a model number?
    By eddiegorniakjr in forum Toilet Forum discussions
    Last Post: 08-05-2012, 12:14 PM
  2. Stove Problem
    By Cookie in forum HVAC Heating & Cooling
    Last Post: 05-17-2011, 09:50 AM
  3. KitchenAid Custom 250 Garbage Disposers
    By Dunbar Plumbing in forum Plumbing Forum Discussion & Blog
    Last Post: 03-02-2008, 03:43 PM
  4. Moving a stove
    By Bassman in forum Plumbing Forum Discussion & Blog
    Last Post: 02-07-2007, 07:13 PM
  5. relocating stove
    By zenrgie in forum Plumbing Forum Discussion & Blog
    Last Post: 08-19-2005, 08:40 AM
