Thread: Water Stopping, Then Restarts Later
    DIY Junior Member Tomcat101's Avatar
    Jul 2012
    Roxboro, NC
    Default Water Stopping, Then Restarts Later
    I have well water. When we use water for a while for filling a tub, taking a shower, washing clothes, watering the flowers, etc., somtimes, but not always, the water will just stop. After a while, maybe 5 minutes, maybe less, the water comes back on. This doesn't happen all the time. It seems sort of random. It's been going on for about a year now. Just when it gets bad enough to think about calling a plumber, it then does fine for a while and we forget about it. As far as I know, it never happens for something simple like washing my hands or filling up a glass of water, just for bigger uses as described above.
    I think we have a submersible pump. I know where the storage tank is and can check it if someone will tell me what I need to look at.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    If you have a shallow well , 80 foot or less, the water table may be dropping below your pump inlet.
    Moderator valveman's Avatar
    Mar 2006
    I think the motor is tripping the automatic overload. It takes a few minutes to cool down then restarts the pump. It happens on the "bigger" jobs because the pump is cycling on and off too much. About the third or fifth time in a row it tries to cycle back on, it trips the overload. The motor was damaged before this started, and it gets more damage every time the overloads trips again. Better get ready to buy a new motor, and figure out how to stop the cycling so it doesn't happen again. It is possible that if you get the cycling stopped now, the pump may last quite a while longer, but there is no guarantee.
  1. tub drain linkage assembly not stopping water
    By karkalec in forum Shower & bathtub Forum & Blog
    Last Post: 04-27-2011, 05:53 AM
  2. water starts then stops for a few minutes then restarts
    By barkeleyboy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-02-2010, 01:24 PM
  3. Water in sump pit consistantly filling, but stopping at drain pipe. Problem?
    By videodronetnl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-19-2008, 06:56 AM
  4. Stopping a leak at the cold inlet of water heater
    By SEast in forum Plumbing Forum Discussion & Blog
    Last Post: 02-01-2007, 06:00 PM
  5. never stopping water pump question
    By ctutuncu in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-19-2004, 07:37 AM
