Results 1 to 6 of 6
Thread: Normal Softner Servicing?
    DIY Junior Member sixgun95's Avatar
    Mar 2012
    Scottsdale, AZ
    Default Normal Softner Servicing?
    All new to me - When do you add salt? How much do you add? Installer told me but just want to make sure I understood correctly.
    Had my new softner put in based on recommendations here, unit & installer - couldn't be happier!
    What were you told?
    And what salt did he say you should use?
    Jan 2012
    California
    Any water softener salt will work fine, solar crystal and pellet salts are usually fairly clean. Mined rock salt can be a little dirtier and may require regular cleaning of the brine tank.
    A regular household of 2 in your area should use approximately a 1/2 to a full bag of salt per month. Simply keep the brine tank full of salt and you are good to go. You should try to maintain the salt above the water level, but on modern timed refill systems, it is not a problem if the salt level gets below the water level accidentaly.
    Congrats on the new system! You will enjoy it.
    Mar 2012
    Scottsdale, AZ
    What were you told?
    When you see water coming level with salt to add. The container is about half full now and I can start seeing the water, seems early to ad salt but what do I know!
    I dont recall exactly what salt he said but its large pellets, I can look tonight. What do you recommend?
    Mar 2012
    Scottsdale, AZ
    DITTOHEAD - You recommended the guy I used here in Scottsdale - awesome dude and excellent install!
    Jan 2012
    California
    Thanks, he is an old friend from 25 years ago when I started in this industry. He has worked for 3 of the major distribution houses in the US, and he was the technical support lead for 2 of them for many years. Be sure to refer him to your friends, he has a daughter to put through college.
  1. Need design advice - 75' well servicing two residences
    By robyn in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-29-2011, 02:19 PM
  2. Servicing a tank - precautions
    By croghanite in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-10-2011, 10:49 AM
  3. Servicing a tank - precautions
    By croghanite in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-10-2011, 07:46 AM
  4. Just what is normal?
    By goat1of2 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-22-2008, 08:45 AM
  5. Gas boiler servicing
    By westleigh34 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-21-2008, 10:02 AM
