Results 1 to 2 of 2
Thread: whistling noise from tank
    DIY Junior Member Paul G's Avatar
    May 2012
    Gainesville, FL
    Default whistling noise from tank
    I have a whistling noise from the tank or pressure switch that seems to start after the well cuts off any thoughts would be appreciated
    Feb 2011
    NW Ontario, Canada
    It would be good to know what kind of tank it is. My guess is the AVC is releasing some air. Does the pressure hold after the pump stops or do you think water is running back to the well?
  1. Shower whistling
    By Jwhitman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-04-2011, 11:46 AM
  2. Pressure Tank Making Noise
    By G Robert in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-10-2010, 06:53 AM
  3. Unusual noise emanating from well tank
    By HS345 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-09-2009, 06:55 AM
  4. knocking noise as in hot water tank
    By kskier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-04-2007, 06:21 AM
  5. Squealing noise from toilet tank?
    By linda1195 in forum Toilet Forum discussions
    Last Post: 09-20-2004, 09:14 PM
