Thread: well constintaly fills aerator tank
    DIY Junior Member deepie's Avatar
    Dec 2011
    fla
    Default well constintaly fills aerator tank
    I have to unplug the pump to stop the aerator tank from overflowing. I replaced the float switch and both pressure switches. If i manually release the concacts on the pressure switch it will shut off, but as soon as i let it go it pumps water again.
    Moderator valveman's Avatar
    Mar 2006
    Don't know. "Unplug, overflow, float switch, and two pressure switches"?? Draw it out or send a picture. I don't know if you have the float switch controling the pump or an electric valve.
    DIY Junior Member coolcat7fl's Avatar
    Feb 2014
    FL
    i have similar problem, except unplugging wont stop, i have to shut off breaker; im thinking it might be a solenoid valve, and posted separate thread on that issue
  1. Well Aerator will not come on when water is tank is low.
    By RobertPod in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-18-2012, 07:51 AM
  2. Toilet fills when you pull lever and water goes down after the tank fills.
    By sxch14 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-18-2011, 12:16 PM
  3. aerator tank
    By jtoboll in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-20-2011, 07:24 AM
  4. Well Bladder Tank Fills Slowly
    By stevester in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-16-2008, 01:35 PM
  5. toilet tank fills repeatedley
    By ronaldo in forum Toilet Forum discussions
    Last Post: 04-02-2006, 07:21 AM
