Trickydick
I need to connect a laundry sink and standpipe to my main. The connection will be a 2" line to a 4x2x4 wye which is at the end of the main; the main stack enters this horizontal line about 1ft. from the end of this wye. I am thinking that if could dump the washer directly into the laundry sink (the 1 1/2"drain which is about 6ft. from the wye) and then run a 2" line and trap to the connection, I'd be all set. My problem is that I don't want the washer by the sink due to space limitations. My thought was to connect a 2" standpipe and trap to the wye and then run a untrapped 1 1/2" line from the sink to a santee on the standpipe. My rational is two-fold: 1)the main would act as the wet vent; 2)if I could dump directly into the sink, why not the reverse and dump the sink into the standpipe. the Is this real bad thinking on my part or is there a better way? IN my area we use the IRC & IPC. Probably should mention that the laundry sink has been draining into a drywell that is now failing; we are now on town sewer. I am a new poster so if a drawing is needed, I'll have to find a way to do that before I can respond. I'm very novice at posting; I would very much appreciate some help at how to attach a sketch or email photo. Thanks in advance for any help
