Results 1 to 2 of 2
Thread: proplem with water pressure
    DIY Junior Member wilder's Avatar
    Dec 2011
    indiana
    Default proplem with water pressure
    Last week my nephew hit my well head it severd a power line I didn't notice the split due to it was in a splice . When I discovered it my water pressure was low now that I fixed the power I still have low pressure my switch will turn on for about ten seconds then off for about two min. Then back on . I still have low presure
    Feb 2011
    NW Ontario, Canada
    Sounds like the pump is going into thermal overload. Either you wired it back up wrong or it damaged the control box.
  1. Water Softener On = No Pressure, Bypass = Normal Pressure?
    By jsarin1 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-08-2011, 04:06 PM
  2. Could my new pressure balance valve be reducing my water pressure?
    By JenJen in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2011, 06:57 PM
  3. Changing water pressure on house pressure regulator.
    By kskier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 09:20 AM
  4. High Water Pressure Spikes on Well with Pressure Tanks
    By RayMan in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-01-2010, 12:57 AM
  5. Water in well, pump working, can't build up pressure, but doesn't lose pressure????
    By bgnotaplumber in forum Pumps and Tanks Well Forum & Blog
    Last Post: 08-20-2007, 10:32 AM
